Try NordVPN to access Netflix or other streaming services from any country and also surf safe!
    BC, Canada
    hi!all!!!
    i just downloaded vcd easy... and when i start da program it tells me that the "WnAspi32.dll" not found!
    how can i fix this? and do i need this?
    Apr 2002
    The State of Frustration
    Yes, you need it. Try a reinstall.
    Hello.
    BC, Canada
    Yo Tommyknocker!!! THANKS SO MUCH!!! for da reply! i really appreciate it!!!! hey i have tried re-installing it over and over again and download it from differnet sites...but still da same!!! (((( do u have any other ideas?
    ya i cant burn now!!! i just realized... and vcd easy is so confusing... to use... well...da instruction that is... i like it cuz so much options..
  4. Member scottb721's Avatar
    Oct 2002
    Australia
    Just let VCDeasy make the image file and use your normal burning program to burn the image. I use Nero for this all the time.
    BC, Canada
    hi scott!!! ya i wish i could do that but i cant cuz I use NTI Cd maker 6 platinum cuz its so easy... but it wont let me burn a SVCD file to VCD... cuz i'm trying to do da VCD header trick... now i just want to burn my SVCD file to VCD...
    any suggetions scott?
  6. Member scottb721's Avatar
    Oct 2002
    Australia
    Can't you use TMPGE to do the header trick.
    Demux mpeg2 file and remux as a non-compliant vcd.
    I've never done it, just suggesting from memory of what I have read.
    Please correct me people if this is wrong.
    BC, Canada
    yup thats what i used the TMPGEnc to da da header trick... now i just need to burn it as VCD with any programs but as i said NTI cd maker 6 wont let me burn svcd as vcd... so i downloaded vcd easy but i got problem to.. missingfile.. mannn is SVCD even worth it ? like is the a great quality difference?
    May 2021
    Slovakia
    I had the same problem while installing and it popup the message This application failed to start because wnaspi32.dll was not found. Re-installing the application may fix this problem. so, I decide to uninstall or replace the wnaspi32.dll file and it just works for me.
