I found a cool intro for VCD's on the net and a cool ending for disk one that tells you to switch disks. I tried merging the 3 files together using mpgtx and it worked great. I now have 1 mpg file that is :
intro.mpg + movie_part1.mpg + change_disk.mpg = Disk1.mpg
This mpg file plays great in QT. When I use VCDToolsX to create the .xml file and the .IMG files it doesn't work. I get one very small file as the result.
What am I doing wrong ? If I just use the original mpg, I can burn the VCD fine. It is after the merge that I have the problem.
-Squeed
Make sure that they are the same bitrate, framerate, size, etc. before you combine them
Joining mpg files from VOB2MPGPRO
By Mudmover in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 2nd Jun 2009, 07:06 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32 -
VDC Quality website
By saladonyourlincoln in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 06:46 -
joining up .mpg movies
By natty in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2008, 06:14 -
mpg joining?
By jay_lubb in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 11:02
