In order to learn these two programs I wanted to take a two disc backup I made with DVDX Copy and make it into a single file again. I was able to do just that but I ran into a small problem, the message that appears at the end of the first disc of a DVDX Copy that says "Insert second disc". This text is added to the end of the last VOB file on the first disc, is there a way with VobEdit or IFOedit to get rid of this text?
Results 1 to 9 of 9
Play around with the VOB stripping in IfoEdit, that should do the trick!!
You can use the preview option in IfoEdit to determine which VOB id the "Insert 2nd disc" message has, then strip this VOB id...
To have all the menu's working again you need to have the original IFO files from the DVD9, quite some puzzling...
gr.
Remco"Drawn beyond the lines of reason. Push the envelope. Watch it bend." -
Hey thanks I will try that. Funny thing is I was looking at the VOB files of the first disc using NeoDVD and I can't even find this message however if I play the disc to the end I get the Insert second Disc. It must be embedded in some other files weird.Originally Posted by Remco
I've done it with the crop function of DVDShrink. Then, just run it on through with no compression.This text is added to the end of the last VOB file on the first disc, is there a way with VobEdit or IFOedit to get rid of this text?
LTA -
That's a great idea since at least I know what I'm doing sort of in DVDshrink.Originally Posted by Triple_Helix
Hey Triple_Helix You're a genius. I was able to find and crop out that text message with DVDshrink plus it even wrote a new set of IFO and BUP files for me.
Bob W... If you can find a way to keep the chapters from disc two -- renumbered, of course -- please post it. I haven't figured that one out yet.
LTA -
I figured that out yesterday. All you need is VobEdit and IFOedit and there is a guide for doing that here.Originally Posted by Triple_Helix
http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl... -
Been there, done that. I joined them using the guide, but only got chapters for the first half. I've tried it a couple of times with the same results. Still, it looks the same as my 9-5 backup, because it wasn't compressed by DXC in the first place.I figured that out yesterday. All you need is VobEdit and IFOedit and there is a guide for doing that here.
LTA
demuxing VOBs with VobEdit
By siluet in forum Newbie / General discussionsReplies: 13Last Post: 22nd Nov 2012, 16:57 -
VobEdit - won't join vobs
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2012, 19:29 -
Cannot get VobEdit to work
By Ramon in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 09:13 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42
