this program has been working OK for me for the past few months, but recently its being ridiculously crappy. every time i schedule a record, it will cut out halfway through with a capture error saying the disk is full. i have 25 gigs free on this drive, so my disk is definitely not full. this is incredibly irritating, because i cant record any of the shows i want to, as they all stop before even the halfway point. yes, i'm recording to DivX which is bad, but i was still able to at least capture before without the damn thing dying on me like this. can anyone recommend anything? maybe some better software? thanks
had the same problems with the winfast software. i'm now using showshifter which seems to work a lot better. one thing I had to do to get it to work is first uninstall the existing divx codec before installing showshifter as it reinstalls the one that comes with it and seems to have issues with existing codec installs.
WinFast PVR captures audio in PCM only
By jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 17:24 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 09:26 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 13:13 -
Connect Winfast PVR 3000 via CD-In 4-pin on SB X-Fi Titanuim Fatality...
By retroborg in forum ComputerReplies: 2Last Post: 11th Oct 2008, 17:33 -
Winfast PVR Interlace capturing, is it possible?
By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 22:46
