VirtualDubMod 1.5.1.1a
https://sourceforge.net/project/showfiles.php?group_id=65889
Virtualdub v1.5.2
http://www.virtualdub.org/
VirtualDubMod Release Notes
[VirtualDubMod 1.5.1.1a]
Belgabor:
- Converted all my stuff to 1.5
- Since Averys error scan works now I ditched my version.
- Assimilated Tdll.h from ffdshow. It provides a class for dll loading.
Also prepared AviSynth filtering inside VDubMod with a Object
encapsulation avisynth.dll
- Included fccHandlers MPEG2 mod. AC3 support is enabled
- Pictures showing whether a command is a keyword, internal or external in
Avisynth syntax completion
- Moved all AviSynth command stuff to CAviSynth
- i18n Completed. Autoloads VDMLang(Three letter code).dll. Custom dll can be set
in Display Properties.
Cyrius:
- Rewrote the MP3 & AC3 import parts which are now used in both AVI (previously
using Nandub code) and OGM menu. The new code has some features to 'handle'
corrupted data (you can throw or keep those data; if kept the code will treat
those data as audio frames and try to prevent audio desynchronisation). Nb :
* when opening an MP3 file that appears to be VBR you will be asked what
to do (as for AVI)
* this new code seems to fix some out of synch issues reported concerning the
use of 'MP3 (CBR) audio'
* this code also store various information concerning the structure of the
file but should take far less memory than the one previously used in the
OGM menu, especially for the AC3 part
- Started merging of AVI 'Audio' & 'Audio2' menu with the 'OGM' one. This should
allow to have more than 2 audio streams in an AVI, and will make my life easier
(I hope) in the future
. All streams 'vital' information are now accessible
in the new 'Streams' menu. This includes a list of all available streams (except
main video of course) and accessiblity to specific settings of each stream such
as interleaving, filters, compression, comments, chapters, ...
The 'Audio' menu features are accessible for each audio stream in the list by
right-clicking on the concerned stream (popup menu).
You can choose which audio stream in the available streams you want to preview.
Keep in mind that audio specific options (filters, compression, ...) generally
requires the audio to be decompressed, so before using those features please
be sure you have such a decompressor, or that the audio is already PCM.
- Removed the 'Audio' menu since its options are now accessible for each audio
stream in the 'Streams -> Stream list' window. This also means that there is no
more audio mode (None/AVI/WAV) since you can add / remove / enable / disable
available streams in this window.
Also removed 'Save WAV' since it is available in the same window.
- The 'FourCC' field in the AVI 'File information' now show the FourCC (4 letters)
and the name of the correspondant codec. Added an equivalent for the audio with
the 'Tag' field that show the wFormatTag value of the audio (hexadecimal value)
and the correspondant codec.
The name of the codec is taken from the Codecs.ini file that contains a list of
known video / audio codecs (this file comes from TCMP, I thank its developpers
for their good player, having made this file and letting us use it
- Removed the 'Audio2' fields in the DubStatus window. The 'Audio' fields now show
the state of the first muxed stream (i.e. not necessarily the first audio stream
of the opened file in case you moved it to another place). The projected filesize
take into account all the muxed streams though.
- Comments in AVI are now loaded (in the video comments list) when opening a file.
- Added a bit of Unicode in the 'Streams' menu. This is only available for Windows
that handle Unicode natively (i.e. it isn't available under Win9x).
You can open external sources which name is in Unicode (well this is not really
useful for the moment since you can't do the same when opening the main source).
All comments and chapters strings should be in Unicode (note that AVI comments
are translated to the ANSI code page; same happens for OGM that doesn't seem to
handle Unicode).
- Added some code to try handling ASCII/UTF8/Unicode SRT files automatically (worked
with an ASCII SRT file and its Unicode equivalent generated by SubResynch).
Note that currently OGM doesn't seem to handle Unicode subtitles so they are
converted to the default ANSI code page.
- Added the 'Set keyframe on chapters' feature in the 'Tools' menu.
- Added DTS (14 bits format not supported) as possible source format.
- Added a new tab ('Audio') in the preferences. This let you access :
* the default preload (in ms) for audio streams
* whether or not the preload must be disabled when not saving to AVI
* the mimimum number of audio frames to pack in a block
* whether or not you want to keep corrupted data (in MP3 / AC3 / DTS files)
- You can't 'Save WAV' / 'Demux' a stream and call another time 'Save WAV' / 'Demux'
or 'Delete' on any stream anymore. Will prevent some of you to play too much and
make crash the program this way
- AC3 is now decoded thanks to liba52 when using 'Full processing mode' or previewing.
Multichannel streams are converted to 'Dolby surround compatible stereo'.
- Added another option in the 'Audio' preferences. This let you use Priss (VirtualDub
internal Mpeg audio decoder) instead of an ACM codec when decoding MP3 streams.
There may be some bugs (in the way I use it, not in Priss
), but it seems this
decoder works better than ACM for MP3 VBR streams
- Added a new 'Streams' tab in the dubbing status window. This tab show you the status
of all the streams being muxed, on the contrary to the 'Main' tab that only show
you the status for the video and the first stream (generally audio) being muxed.
- Fixed (I hope) the bug with the About box.
- Now use the Corona library to handle other image formats. BMP and TGA are handled
by VirtualDub internal routines, and PNG / JPEG / GIF / PCX are decompressed
on-the-fly to BMP thanks to Corona when opening an image sequence. You can save
image sequences to BMP, TGA (handled by VirtualDub) or PNG (handled by Corona).
Note that Corona only support PNG output (no BMP, TGA, JPEG, GIF or PCX).
- Added 2 items in the 'Video' menu to let you take snapshots of the input or output
video and save the image to a file (BMP, TGA or PNG format).
- Added a 'Report' item in the 'Streams' menu. This show you a short report on all
current sources opened (main information on the stream, plus some additional).
- Enhanced a bit the Ogg/OGM import filter so that it can still open (and try to
correct a bit) badly corrupted files (files that would give you an 'Invalid Page'
error and wouldn't open in previous versions). The program also try to artificially
(i.e. no real data are inserted, only time indexing is modified) 'compensate' for
lost data (in order to minimize audio/video out-of-sync).
- Vorbis streams are now decompressed when in Preview mode or when using the
'Full processing mode'. Only the first 2 channels are rendered for multichannel
streams though.
- Merged 'Save as AVI', 'Save old format AVI', 'Save segmented AVI' and 'Save as OGM'
in a unique 'Save As' box (you select the format to which you want to save, the
last you chose being remembered, and you can decide to save in old format AVI or
to segmented files when available).
This new 'Save As' window remind you (and let you change) the current video mode
(Direct stream copy, ...) and the selected video compressor (when recompressing).
Thanks to sysKin for the idea and a layout example of this 'Save As' box
- Added the possibility to segment the output OGM file (in 'Save As' box).
- Fixed a bug allowing chapters belonging to masked subsets to be kept.
- You can now demux subtitles to an ASCII / UTF-8 / Unicode SRT file (ASCII or
Unicode being choosed by default depending on the type of the input).
- Added a new 'Main' preference : the default Video mode. You can now choose in
which mode (Direct stream, Fast/Normal recompress, Full processing) start VDubMod.
- Updated the available Language list (Stream comments) to follow the ISO-639-1/2
standards. By default languages defined in ISO-639-1 are listed; other languages
(ISO-639-2) can be accessed thanks to a checkbox. If a known language is selected
the output format (e.g. OGM) will take into account the standard (English Name /
3 letters code / 2 letters code if available). (information on ISO-639 can be
found at http://lcweb.loc.gov/standards/iso639-2/englangn.html)
You can still use user-defined languages (and overcome the standard) ...
- You can now append OGM segments (either automatically when opening an OGM file
or manually by using 'Append segment'). Streams are merged as is (no correction
is made if a stream ends at a different time than the video one).
Stream comments and chapters should also be appended 'correctly' (i.e. there
shouldn't be duplicated entries if comments are exactly the same, or chapters
have the same name and the difference between their time is lower than 2ms).
- The file position shown in the control bar (frame number, ...) doesn't take into
account external sources now (overhead on those can't be accurately computed).
So it only shows the position of the current frame in the file.
- The deleted/masked subsets are now reapplied when doing a Refresh.
- You can now specify to which file you want to save frame information when using
the /log option (e.g. /log"c:\YourPath\YourFile.log"). Also the log file now
use '\r\n' for ending lines instead of '\n' alone.
- The 'Display' preferences now let you choose to have 'Display input video' and
'Display output video' checked or not when starting VirtualDubMod.
- Started to add a basic Matroska support. See http://www.matroska.org for more
information on Matroska.
Nb : as you can imagine all this implied a lot of changes in VirtualDub and
VirtualDubMod sources ... which means there may still be a lot of bugs ...
Stone-D:
- Merged Auto-Resize and added to Display Preferences. The initial resize when
VirtualDubMod starts follow the preferences choice too.
- Implemented ASF parsing. Same as before, to activate it you must
uncomment '#define ALLOW_ASF_PARSING' in VirtualDub.h.
Windows 7 and VirtualDub/VirtualDubMOD
By thedarkinvader in forum Video ConversionReplies: 18Last Post: 21st Jul 2012, 06:40 -
Virtualdub or Virtualdubmod for DV AVI trimming?
By sasuweh in forum Video ConversionReplies: 8Last Post: 19th Oct 2010, 21:31 -
Blank video with MPEG2Source in Virtualdub but not Virtualdubmod
By txporter in forum Newbie / General discussionsReplies: 2Last Post: 31st Mar 2010, 15:17 -
BD to AviSynth (Or VirtualDub/VirtualDubMod) ???
By RogerTango in forum Blu-ray RippingReplies: 4Last Post: 3rd Jan 2009, 08:31 -
Aspect ratio problem using virtualdubmod or virtualdub
By anindyanuri in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 08:31
