This question could be posted in a number of forums but this one looks most likely....
I have ripped a DVD-PAL to my HD and have sucessfully converted it to fit on a DVD-R using Instant Copy. So far so good.
Is there a tool that can convert a whole DVD disc from PAL to NTSC leaving all the menus and movies intact?
I could just rip the movies, convert them and put them back onto a new disc. But I'd rather not.
Essentially I need to convert a PAL DVD-9 to NTSC DVD-5
Anyone know what to use?
I used IfoEdit to change all occurrences of PAL 625/50 to NTSC 525/60 and burned the movie that way. It works on my combination (NEC NDV22-R DVD player and Toshiba 57H82 Widescreen TV). Not sure why since the video streams are still marked as 25 FPS, maybe the TV can sync at that rate.
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 17:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
