Please, help me you guys - I just bought the first of these two computers (the Sony one) and I'm largely conflicted now - thinking that maybe I should have bought the second. This decision is based primarily on the fact that I can't find DVD-R media anywhere and the software I got with the Sony is somewhat useless to me - also that I've heard that the Athlon has better performance, etc...
Some please let me know which one is better - which of these two computers is the clear choice? Thanks:
1.
Computer 1
http://www.bestbuy.com/detail.asp?e=11216332&m=488&cat=490&scat=491
VS
2.
Computer 2
http://www.bestbuy.com/detail.asp?e=11216641&m=0&cat=0&scat=0
Results 1 to 11 of 11
i personally have the first one and that works great, good speed and everything
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
I also think that the first one is the better choice.
SLICK RICK
Originally Posted by lordsmurf -
AMD+ is not as good as P4 for video (SSE)
The first one is fine (the P4), though I'd suggest looking at another brand, as Sony has bad tech support and my friend bought a Sony that had no OS loaded or anything. Luckily he had me to fix it, but that's bad service.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
The first one.
Buy DVD-R online at www.rima.com or www.meritline.com or one of the many sites out there. They are cheaper and work fine...Use what works for you... -
yo, does that sit what you just show us carry double density cd-rs..holla
thatgentleman,
I choose [None of the above], build your own. It's not hard and there are how to's everywhere if needed. If you are still uncomfortable with the process, find a local, REPUTABLE, [ma' n pa] computer merchant and tell them what you really want!
I know there was not an option #3 given.
justmy2cents
PS:Be advised though, it is very habit forming, I know!!(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
i have a sony with pioneer ao4 and i do all that i want and quickly, support is great and the software is phenomenal . the sony (sonic) line of software is all good and this awesome computer will do everything you ask it to and its easy to upgrade. i have one complaint and thats no tv out card and the authoring software i got was junk. i slice through encodes and breeze through burns
First One. But like other post I custom build my own. Built the way I like um. Maxed out with the latest and best hardware across the board. I'm a mod junky.
First one, I also agree with the others build your own.
neither one, both are junk , build your own and don't worry about the overly priced P4's my AMD blows away my friends p4's all the way and are half the price, picked up a mobo 2600+ for $129 half the price a P4 2.4 was and still cheaper than a P4 2.0 go with a 1gig of ram, much better with XP than 256 or 512. Plus the CPU case you can buy for $60 is alot better than the crap from SOny or HP, cool, cool, cool, is the key to great running computer, heat is your worst enemy. I carry 3 chassis fans, I cool master cpu fan, hard drive fan, video card fan, no lockups here.
have no probs making my own DVD's and burned over 300+ using my HP DVD+R burner without a prob.
Need help deciding on a computer to buy
By jboogygroove in forum Newbie / General discussionsReplies: 12Last Post: 4th Apr 2010, 12:50 -
Have a Virus? Buy a New Computer!
By 3Simon7 in forum ComputerReplies: 26Last Post: 28th Oct 2009, 05:50 -
Time to buy a new computer
By Haopengyou in forum ComputerReplies: 2Last Post: 11th Oct 2008, 01:01 -
Don't buy...build your next computer!
By rcguy1 in forum Newbie / General discussionsReplies: 38Last Post: 17th Sep 2008, 12:12 -
Have to Buy this week ! !! computer for ~1200 ?? please
By Dash1 in forum ComputerReplies: 10Last Post: 22nd Apr 2008, 18:32
