hello can anyone help on telling me how to turn on DMA for the DVD rom?
I just bought a toshiba 16X and its ripping at only 1x using "Smartripper" and I read in some other forum that by turn on DMA it should speed up!!!
but if anyone knows something else please help... I tried looking for it all over the place...
THANX +++
Hi,
Hope this is right,
Right click on your MY COMPUTER ICON on your desktop, Choose DEVICE MANAGER then choose CDROM(either double click on it or hit the + at the side), Double Click on your TOSHIBA and the choose SETTINGS, you should see the DMA setting there if it's not TICKED the tick it HIT OK and then it should ask you to restart your pc, do so.
Hope that helps.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 11:10 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 14:15 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 23:35
