Hi
I am trying to make a VCD/DVD with episodes of 24(VCD).
I de multiplex(tmpeg) them and convert the audio to 48000khz(besweet ssrc) so that I can author them with spruce maestro.When watching the finished dvd compiled to my HDD some(not all) of the episodes go gradually out of sync.Since then I have tried to figure out the problem using one of the trouble episodes, but everything I try fails.
So I need help. the VCDs are NTSC 29fps
thnx
...and what is your source material? Is it also 29 fps? If not, the desync is certainly caused by frame rate conversion.
/Mats -
Also, if I de-multiplex them in tmpeg then, multiplex them back imediately after, without adjusting them whatsoever. The resulting newly multiplexed file is out of sync.
W....T....F -
TMPGEnc only promises to handle mpegs created with TMPGEnc correctly - specially when muxing! If the mpeg is encoded with something besides TMPGEnc, the result is unpredictable at best...
/Mats -
Well I have tried other programs to demultiplex it... no deal, it still fuckin wit
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
