hI,
I have a Pinnacle DC 10 plus and usually convert NTSC analog video by making that humongus big Mjpeg avi file and then converting it to dvd format with TMPGEnc.
In this case I have a few PAL DV tapes I would like to convert to DVD format, but the family is in Canada and they have only NTSC DVD readers/tvs.
Therefore I would like in as few steps as possible to convert my DV tapes to NTSC DVD for later burning.
Any ideas would be appreciated.
thanks![]()
Well, the highest quality conversion between NTSC & PAL, or vice-versa, is if you use the method developed by the very talented Xesdeeni:
http://forum.doom9.org/showthread.php?s=71a1ff358c266d0e42b0ecc547ac1ba8&threadid=45459
Failing that, the next best option is to use Canopus ProCoder.
Arky ;o)
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
Transcoding PAL v/s NTSC?
By wulf109 in forum DVD RippingReplies: 1Last Post: 13th Sep 2008, 00:11 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
