Hi,
I have Family guy on DVD and want to back them up. Trouble is each disc is 7.08 gb and needs heavy compression. I want to use DVDShrink as ive had good results with it before. But in the help file on this site, it says not to go below "5" in compression. It needs to be about 8 to fit properly.
Help
John
Don't do the unthinkable, split it to 2 disks. The alternative is to re-encode it to 1/2 DV. Spend the extra $1 and have a perfect backup, instead of an overcompressed copy.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
mrspangle,
Gazorgan is right. I needed to back up the Simpsons episodes and each DVD was 7 Gig and above. So, what I did was to look at the number of episodes per disc. For instance, the Simpsons had 6 episodes per disc. So, to make my life easier, I put 3 episodes per disc and I used DVDshrimk to split them (the easy way). The quality is outstanding!!
It's not that I don't understand, it's just that I don't care!!!
Best settings for anime encoding?
By The Scenes in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2011, 18:28 -
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 18:07 -
help encoding anime w/ handbreak
By Ronin Silfar in forum DVD RippingReplies: 22Last Post: 29th Jan 2010, 21:28 -
Encoding anime
By prnoct90 in forum Video ConversionReplies: 3Last Post: 25th Nov 2009, 05:38 -
Anime Encoding From DVDs to h264.
By kwanbis in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2009, 19:31
