Man, gradual A/V sync problems are tough to deal with. I've tried everything. Sonic Forge just didnt' do it for me, and I followed both guides listed on this site exactly. I read somewhere that Goldwave's TimeWarp feature was good for doing this, but I'm not having much success there either. In Vdub, the movie says it's 1:56:54.787 and in Goldwav the audio says its 1:56:58.031. Does this mean that I need to compress this audio file to the exact same time length as the video? I tried doing this, and it still was outta sync.
I later discovered that the movie seems to be in sync till a certain point (about 2/3 the way thru the movie) and then the gradual out-of-synchness begins. Is this even possible? How would you recommend that I fix this problem? Any insight would be appreciated...
Thanks!
My advice is, (assuming the movie is an SVCD), re encode it from the original source.
If the problem's with the original, delete it and get the movie somewhere else.
Fixing audio sync problems are more hassle than they're worth.
You could spend ages on it and still not get it perfect.
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 12Last Post: 20th Dec 2014, 12:31 -
How to fix gradual loss of sync once and for all
By Acidagent in forum User guidesReplies: 76Last Post: 22nd Oct 2009, 07:39 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
Fixing sync problem on rmvb
By gameroftheuk in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2008, 22:16 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 01:33
