I'm from holland / the netherslands
and the most talked about dvd-r are
That;s write
data write
princo
vebatim
Ritek/ICCIP
ritek
blank
Princo is the baddest all my dvd's i burned are f ed up
What is ICCIP ?
In holland they dont know much they just sell
Maybe you guys can help me out
From what I've read and heard, those brands are not necessarily the best. But, they are rather cheap in bulk as far as cost goes. As for quality, I have never used any of those brands. I mainly stick to Fujifilm brand DVD-Rs. I have also used Apple, Memorex and TDK brand DVD-Rs with no blocking, pixelation, etc...and some are burned to almost the very edge of the DVD-R. I would rather pay a slightly higher price, instead of saving money in the short-term and find my "backups" unwatchable in the near future. However, I do realize that some of us in this particular hobby do have a limited budget.
*I used Nero Infotool and found that some Fujifilm DVD-Rs I bought were made by Taiyo Yuden. So, I bought some more! -
Hi,
I'm from holland to and use Platinum and Imation.
No coaster yet and they work flwaless on both my Pioneer players and PS2. For now I stick with Platinum the right price and about quality the only thing I can say is time will tell. They look sollid and I think they are allright to use. The really cheap dvd's are the ones I keep away from just like the no name ones.
(Zeker op de beurzen kan je goedkoop platinum verkrijgen 1,60 per stuk)
CYA,
DVDGEK -
Hi, I'm from Belgium, that's close to Holland; I have a Pioneer A103 in my Mac and a Panasonic DMR E20
for most critical items I use Maxell or Fuji, never had a problem;
for "cheaper", less ctitical things: Optodisc, Datatrack: results are generally good, just an occasional coaster;
the media that are more problematic for me and I don't use again: Imation and Sentinel
