I just got this dvd burner but when i put it in it only sees a blank as a 1.9gig audio disk in windows ME.
When i run it in XP it is ok no problem's at all.
i have noticed 1 or 2 posts on the forum where the ueser's are running the same drive in ME
Any help would be appreceiated
cdfake@hotmail.com
I've been using this burner and it definitely CAN work under Win ME, but I also had probs due to the drive failing. My replacement is still working so far (touch wood)...
Can it play DVDs under Win ME, or does it not recognise any DVD format?
Make sure you are using a recent version of your burning software and see how you get on. Try using a few types of DVD-R/RW (though my drives have seen all the cheapo disks that I've tried them with).
Sorry I can't give you any more advice, but I would say hang on to your receipt because I'm not sure that this drive is the most reliable... -
Hi m8
Yes i can play a dvd film with it in ME
What software do you recomend ?
E-mail = cdfake@hotmail.com
Thanks -
Hi there,
I have been using Nero to burn - version 5.5.??? (can't remember - it's on my PC at home, but I'm using an update which I downloaded a few months ago). It seems to work fine, and it burns DVD-Rs at 2X, and I can get the disks to work on all the players I've tried so far, including PS2.
I think you can download a trial if you don't already have Nero, but there are other options - try the Author guides to the left, and good luck!!! -
cdfake - here's your answer...
I normally only pop a DVD-R into the drive when it's needed by Nero. But I put one in when running Windows Explorer last night, and Win ME did indeed see it as a 1.99GB audio disk. Strange. But then I loaded Nero and it went on to burn over 4GB of files to the disk, so no problem. This is just a strange quirk which doesn't affect the ability to write to the disks...
VAIO E series Matshita BD-CMB UJ141AS
By difoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Mar 2010, 19:56 -
Replacement for dead Panasonic / Matshita UJ-220S with ATA interface
By Persistence in forum DVD & Blu-ray WritersReplies: 1Last Post: 21st Feb 2010, 10:53 -
Problems burning DVD+R DL with Matshita UJ-850S
By Pablo2k1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Jan 2009, 11:06 -
Help with Matshita Drive/Adobe Encore V2
By bailout in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Aug 2007, 14:16 -
matshita dvd ram uj 840s
By skaterboii in forum DVD RippingReplies: 3Last Post: 16th Jul 2007, 05:11
