BIG problem!
first i tried to convert my xvid in Ulead moviefactory2 while authoring but i can't get "keep aspect ratio to work" ( so it screws up the resolution).
then i tried to convert it with tmpg, but because the first frame is a xvid (green not proper working) frame, tmpg quits or doesn't work. So i used virtualdub to cut out the first couple of frames, but i get while opening the file, an error message about vbr error bitrate error etc.
then tried to seperate the sound by saving it as a .wav file. and combine movie and sound in tpmg...that works fine but i get an audio sync problem!!!!!!
Can somebody help me getting an xvid on proper working dvd+r with good sound and very important KEEP ASPECT RATIO!
More audio sync problems (MPEG2)
By mahonni in forum AudioReplies: 41Last Post: 15th Jan 2012, 16:08 -
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 15:02 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 09:38 -
Help! VirtualDub video/audio out of sync when enconding MPEG2 to XVID
By kbal in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 16:05 -
vob/ifo to xvid audio sync problems.
By spiked in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 18:19
