Please someone I need help? I been copying DVD's successfully up untill now! I use DVD Decrypter ver 3.1.6.0. I keep getting this error?? Then I use DVD 2 One ver 1.1.3.
Here is the url of the screen capture error!!
http://208.184.9.171/DVD Decrypter Minority Report Error.jpg
Thanks![]()
i think you may be better off with clad or smart ripper for the film minority report it is a tricky one to do.i think if you rip it in the standard way with dvd decrypter the first 6 minutes of the movie aren't there,whereas the results are different with clad or smart ripper.
By the way i couldn't check your jpg link.[page not found error] -
Try this link? http://208.184.9.171/DVDDecrypterMinorityReportError.jpg
Code:Ok I will try Smart Ripper, Where to I get it?
who's the hottie on your desktop wallpaper?
she looks "wet" or "sweaty" -
I just backed up the movie using decryper 3.1.6 and dvd95copy 1.5
Ripped no bother and transcoded in inder 1 hour using latest version.
dlb. -
i try to rip minority report to hd using dvddecrypter 3.1.5 and no problem
and itīs seems that the media is bad
try another dvd disc (minority report)
This Virtualdub crash report mean anything to anyone?
By brassplyer in forum EditingReplies: 4Last Post: 30th Jan 2011, 20:35 -
A really hard techy question regarding an error report from my master DVD
By polyphasic in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2010, 14:05 -
help slow computer, Hijack this report
By maxamillion in forum ComputerReplies: 13Last Post: 22nd Apr 2009, 00:38 -
How do I report a bug in SUPER?
By rafwuk in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2009, 10:39 -
EyeTV 250 Plus Capture Report
By quicksilverg4 in forum MacReplies: 0Last Post: 10th Aug 2008, 14:34
