Hi,
first of all, sorry for my english.
I try to make a SVCD with 2 audio file (french and english soundtrack)
I've read the guide, made what he said, but when I enter in my standalone player (Samsung S321), the dvd tell me "No Disk". He can read SVCD with no problem, but it is normal that he cannot read a SVCD with 2 audio track?
This is more useful info:
- My audio track is made from a WAV to MP2 using TMPGEnc, at 44100@128bpbs@stereo (i've try JoinStereo, same result)
- I've put the bitrate to 2000 to be safe, just in case to not reach the MAX and get error in playback (because of the limit of the datarate)
- My DVD player is a Samsung model S321, can read MP3, VCD, SVCD without problem in CDR and CDRW.
Can someone explain if i have miss a thing, or my player cannot handle the multi-audio-track?
I would think that any SVCD compatible dvd player would be able to play a compliant SVCD with multiple audio tracks.
I think you may be following my guide...
Are you doing anything different then you normally do when making a SVCD? For instance, many people have reported problems with TMPGenc's multiplexor so if you normally don't use it, and are only using it because my guide uses it then this could be your problem. I strongly recommend that you always use bbmpeg to multiplex, it does a much better job than TMPGenc. -
Ok... I will try step by step the procedure... and use BBMpeg to multiplex the file.
I will give comeback!
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
