i have tried the header trick suggested in the convert section and it seems to work on some of the movies, but not all. at one time i had the movie end 5 minutes earlier then it's supposed to and another instance, the audio and the picture isn't synced. any help would be great.. thanks
bettie
Results 1 to 1 of 1
"never say goodbye if you still wanna try. never give up when there's still hope to go on. never say u don't love them, if you know that you are the one that can't let go"-(unknown)
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
Extra High Grade fail
By Abas-Avara in forum Capturing and VCRReplies: 2Last Post: 1st Oct 2009, 14:56 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
Current HD standard is a FAIL
By simps in forum Newbie / General discussionsReplies: 78Last Post: 20th May 2009, 05:08 -
percentage of hard drives fail
By MJA in forum ComputerReplies: 29Last Post: 4th May 2009, 11:44
