I'm using CCE SP, when I tried to convert a 23minute AVI file into mpg, it makes a 1.1 GB mpg file. TMPGenc makes around the same size as my input file. Am I doing something wrong? Also why can't I input a seperate audio stream like I can in TMPGenc?
IN CCE SP, I'm encoding with MPEG-1 System
Within CCE did you right click on the selected avi and set the mpeg options. It sounds like your bitrate is probably defaulted to 6000.
There's not much to do but then I can't do much anyway. -
If you plan on making a videocd to play on a standalone DVD player then choose that option for "mode" and it will set the bitrate to standard for you.
If your DVD player accepts off spec (x)vcd then you can boost it up to 2500 if that's the only clip that will go on the CD. A 23 minute mpeg should fit at that bitrate.There's not much to do but then I can't do much anyway.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
How to Convert AVI to DVD + AC3 with CCE and AC3Machine
By ta2 in forum User guidesReplies: 40Last Post: 21st Jan 2010, 18:01 -
25fps AVI > NTSC DVD - am I doing this right? (AviSynth, CCE, DGPulldown
By fischkopf in forum Video ConversionReplies: 25Last Post: 22nd May 2008, 19:31 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
CCE SP avi video wrong length
By skipadipadoo in forum Video ConversionReplies: 4Last Post: 7th Nov 2007, 11:14
