Hi there,
I have got 2 AVI files that make one movie and I want to merge them and then cut in 2 back again because I don't like exactly how they are currently split. I know that I can do it in TMPGENC once I have them converted into MPEGs but maybe it's better to edit while they are still in AVI ? What software is best to use to edit AVI if it makes sense at all?
Kuzz
It's best to do it with the avi, use this guide: https://www.videohelp.com/virtualdubedit.htm
8)"Art is making something out of nothing and selling it." - Frank Zappa -
yeah, thanks, I just saw this guide. but now my problem is that the 2 pieces overlap a bit and I do not know how to remove the duplicating piece within the merged file.
Kuzz -
Personally I wouldn't have bothered joining the movie prior to encoding with TMPGenc...I'd use the source range feature in TMPGenc to cut out the overlap that you mention.
Now its done though, you can always cut it again with Virtualdub, but this time you'll be cutting the movie a) up to the point that the overlap occurs, then b) starting the next cut at the point that the overlap ends. Then if you want to join em up into one file use virtualdub again to join....as I say, best to use TMPGenc's source range feature to start with!
AVI Merge (XviD)
By Asesinato in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 05:37 -
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 02:25 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 13:11 -
Merge several avi:s untouched ?
By offer in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2008, 14:19
