hello
i am trying to burn my graduation made dvd on another blank dvd for my
mom
everything looks fine
i put it in Nero and
it burns out a cd. but the cd wont play anywhere
LIke it's blank or somethign but the cd has written information on it u can tell when u flip it over
it's been doing the same with audio files it burns and then they wont play anywhere
i even tried easy cd creator
is there
a fix to this problem?
please
help!
Results 1 to 11 of 11
Your description is a little confusing
Is your "original" disc a DVD or a CD, and are you trying to copy the contents of that disc onto a blank DVD or CD?
If you are dealing with an original DVD and a blank DVD, it's not going to be as simple as copying a CD. With DVD's you can't just put the discs into Nero, or Roxio and say "create copy""or copy disc". If your original disc is a single layer DVD (which I'm guessing is the case if your just had your graduation video put onto DVD) you could use DVDDecrypter to "read" the ISO files off the original disc, and then insert the blank DVD and have DVDDecrypter "write" the ISO files back on that disc.
Do you have a DVD R/RW drive? -
well Yes the original dvd is placed of our graduation
and then i decrypt it using DVD decrypter and all
then i drag the files in the video TS folder etc and burn with my dvd burner Pioneer A05
i have never got a problem like this before..
using nero.
what it does.. it goes through the whole bunring effect and writes on the dvd or Audio cd but when i go play either the dvd or audio cd nothing plays though if u turn the cd upside down u can see the the write has written information on it......
i even tried adaptec easy cd creator and i am getting the same problem it's burning but nothing play even on a home cd player or anything.. -
You can just forget nero, adaptec, and all the other burning software for now. If your original DVD is a DVD5 (1 layer, under 4.7GB(really 4.38)) you can simply use the DVDDecyrpter "ISO" steps I mentioned earlier. This is about the quickest method for a simple, exact copy of another 1 Layer DVD.
what it does.. it goes through the whole bunring effect and writes on the dvd or Audio cd but when i go play either the dvd or audio cd nothing plays though if u turn the cd upside down u can see the the write has written information on it......Use what works for you...
yeh sorry.
I meant i am copying it to DVD it wont play anywhere not even my dvd player or my computer dvd player
and adaptec and nero aare doing the same thign wtih my AUdio cd's it burns and then they wont play anywhere!! -
Sorry I am a bit confused are you copying a dvd to another dvd or a dvd to a vcd ?, you talk of burning but you do not mention any sort of converting or editing, have you done this already ?.
yeh all the coverting and all has been done.
so this is DVD to DVD....
i cant figure outthe problem, i have done this before and it has worked
and now it wont.
i mean it burns, takes it time but when u try to play it nothing
i mean Even with AUdio cd's my pc is burning them u can see it work
and it wont play them anywhere..
