Does anyone know of any web sites with good info on HDTV tuners etc for use in the USA? Thanks
I caught info on WNBC TV's web site the other day on HDTV. Not only NBC, I've got some other links here as well, some only basic info, others very technical and also consumer info as well. Check them out:Originally Posted by pharries
http://www.wnbc.com/technology/1455530/detail.html
http://www.ee.washington.edu/conselec/CE/kuhn/hdtv/95x5.htm
http://hdtvinfoport.com/
http://web-star.com/hdtv/hdtvnews.html
I suggest finding more using Yahoo Search: http://www.yahoo.com/ -
A forum for HDTV. You can search it.
http://www.network54.com/Forum/213962Don't give in to DVD2ONE, that leads to the dark side. -
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 20:12 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
