Results 1 to 10 of 10
    Dec 2002
    Southern USA
    Is there any other cd burning software other than Easy CD creator and Nero Burn? I have alot of trouble when I use Easy Cd Creator and Nero Burn it always re-encoding my files even after I have encoded them with TMPGEnc. Also is there any CD Formatting software? I was using Direct CD but now since I have reformatted my hard drive it does not recognize my cdr drive.
  2. Member Conquest10's Avatar
    Chicago, IL
    vcdeasy
    His name was MackemX
    Jan 2003
    Nassau, Bahamas
    it has to really suit your needs and your burner to an exten, for me, its only nero, it overburns, i have all the plugins so it just becomes more amazing afterwards...holla
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  4. RecordNow Max works for me.
    Dec 2002
    Southern USA
    Do anyone know of a good cd formatting software? DirectCd doesn't work for me.
  6. It seems like DirectCD doesn't work for anybody!
    I haven't had any luck with other "direct writing" packet CD software either (such as File CD). The technology is inherently difficult and it seems that no new programs have solved the problems.
    But all this direct writing software is no good for any type of video CD work anyway. It is only good for data files.
  7. CDRDAO is a good burning program.
  8. I would have to go with nero or vcdeasy.
    If it's wet, drink it
    My DVD Collection
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    CDRECORD and CDRDAO. Provided you have a nice ASPI layer setup. Add MKISOFS to this, and there's nothing you can't do, when it comes to CD burning.
    /Mats
  10. after i use vcdeasy to make it as a bin/cue, i use Blindwrite to burn it...
