You all probably know me by now do if someone can answer this question, you might be able to encode a movie as long as 2 hrs using a bitrate as high as 1500 with no blocks on 1 CD!!!!
Here is question-
I know that changing the vbv buffer size effects file size.
The standard when using automatic, tmpgenc uses 40. If i were to set it at 20, would it lower the quality of the video or if it did or didnt do that, would increasing the bitrate make the quality better?
See i thought that if i lower the it to 20, then raise the bitrate high, it will produce no different effect.
If anyone can answer any of these questions, it will be GREATLY appreciated and to come, the worlds first high quality longest movie at 1500 bitrate+
Results 1 to 1 of 1
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 16:38 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 04:45 -
Help: ImgBurn Buffer Device @ 59%
By butt_crack in forum ComputerReplies: 2Last Post: 5th Feb 2010, 18:22 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04
