hi,
ive been browsing the forums for a few days now and i still dont have an answer!
im trying to convert an avi file into dvd format, so i used tmpeng and converted it to mpeg format, but when i burn it onto dvd it wont play in my stand alone dvd player, whyi heard that the files were supposed to be vob, ifo and bup files, if so how do i get them into this format
replys appreciated
David Crabb
Results 1 to 11 of 11
you have to author a dvd. https://www.videohelp.com/author
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
u can demux the mpeg file so that u have a .m2v file and a mpa file using TMPGEnc. then u can use ifoedit to turn them into .vob files. just select dvd author at the top of ifoedit and u will get another window. in here just input the video and audio files, click on a destination folder and hit start. after its done it will make all the vobs as well as .IFO and .BUF files too. just make sure that ur dvd player can play DVDx. i think thats what they call it. i have an apex 1100w and it can play this type of format.
I just use a program called 'NeoDVD Plus" to do that. It's simple and will create all the files you need plus burn the DVDR for you.
http://www.mediostream.com/products/neodvdplus/index.html -
thats even better then....when using NeoDVD Plus...u wont have to do all those steps. just a few simple clicks and off u go
Neodvd has to reencode the video file unless you captured it with neo,
i would stick to ifo if you are happy with tmpeg results neo will reencode at real time on my machine but still adding a heck of a lot of time onto your project -
no problem me01273,
always glad to be of service. and like john said if ur happy with the results from TMPGEnc then just use ifoedit after that -
hello again,
im abit confused you said demux a .mv2 file using tmpgenc, but mmm...
i dont know how i cant see anything init that will alow me to do this,
reply appreciated
David Crabb(me01273) -
In TMPEG click File,the MPEG TOOLS,that will open the demux/remux dialog.
as wulf109 said,
go to the tools section and once ur in there. select the tab that says simple De-multiplex and load up ur mpeg file. then after a few minutes u will have both of ur files that u want
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
Vob to mpeg-2 question
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2008, 23:16 -
Converting .mpeg to .vob
By demonwarrior in forum Newbie / General discussionsReplies: 12Last Post: 17th Aug 2007, 01:33
