before i posted here as the rules is,i did some search around site but at least i didn't find same situation like me.
okay i know how can i convert or cut or play and etc a vcd or svcd and etc.i hase a filme which is in divx and i want to see it in dvd player(i know my dvd player support it)well as i siad before i went to site and i found my answer.i encoded whole filme to mpeg1 with TMPGEnc this pretty nice program.
Here began my problem i put first cd in dvdplayer it was black and white then i put second cd it was fine(with colour) then i put last cd in and it was like first one 'blakc and white' i don't no what could be the reason????
because i encoded all the 3 cds in same way as each other but just one of them worked fineand i burnt them with neroburning program
could some1 help me to find out problem???
Results 1 to 11 of 11
what were your settings?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
thats fucked up....i dont have an answer...
...holla
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
i followed all things wrote down in this page step by step
https://www.videohelp.com/tmpgenc.htm -
Can you play the divx files on your PC using Media player Power DVD or the like? Do they play OK?
If not, it sounds like a codec problem. Get Gspot from the Tools section and test your files. It will tell you the required codecs and if they are installed on your system. Get and install any required codecs.
8)"Art is making something out of nothing and selling it." - Frank Zappa -
yes they work fine in pc but when i watch them in dvd just one of them is with colour
No1 can help??
come on guys for god sake ,no1 find here who can answer or help me about this situation?
Sounds like a region problem to me, are you ntsc or pal. Make sure your file is encoded to the same format.
Does that fix your problem ? -
at least some1 found to help me
,anyway okay as i sadi before i had a film which was in divx and it was 2 part each of them were more than 1 hour so i decided to cut them to 3 vcd.
well i followed tutorial about TMPGEnc program which is in site so after hours finally i encoded them but 1 thing was strange to me and that was:
the original(which was in divx format)file had 2 different frame size because first cd was 29,..fps and second one 25,..fps so as you see first one is NTSC and other one PAL.
when i encoded them cds 1 and 2 is in NTSC and third is in PAL but as i mentioned just second cd worked fine.
and i'm living in europe -
is it possible that yer dvd player can only play 1 type of format, possbly ntsc only or pal only, what other formats have you played and worked ok
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 19:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 05:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 12:20
