Here's a confusing problem - I can't seem to cap from my DV cam. It's connected fine, and the machine controls work, but weird things happen when I capture:
In Vegas 4.0, every 2 seconds it pauses in the preview window - for about 5 seconds. It shows no dropped frames and the tape timecode clicks away like normal. But when done, the AVI is corrupt. It does this with 2 cams (Sony TRV120 and TRV110) and both 4.0 and 4.0a do it.
The DVD Workshop trial 1.3 seems to capture fine, but it's AVI is corrupt as well when I port it over to Vegas for editing.
I think this is the first I've tried to capture in Vegas 4, so I tried installing Vegas 3, which I KNOW worked before on this system - same deal. The system:
AMD AThlon XP 1800
Soltek mobo - VIA 266 chipset
512 MB RAM
2 drives - 10GB system, 80GB capture, both 7200RPM ATA66+ and defragged.
Win2k SP3
Any ideas?
Results 1 to 1 of 1
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Missing or corrupt file in Win2k
By bevills1 in forum ComputerReplies: 8Last Post: 10th May 2008, 21:43 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 14:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 18:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 12:21
