I have a few movies that r AVI's in two parts. i.e. CD1 and CD2. i know that i need to TMPGEnc to join and save them, but what settings would be good to se in DivX or Xvid to encode the new file. i dont want to lose quality. (is this possible) what settings for the encoder should i use to do this? or should i even try? i would like to be able to burn the final divx/xvid file to a CD. any suggestions? thanks
Results 1 to 13 of 13
you can join them in virtualdub and just do a direct stream copy.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
https://www.videohelp.com/virtualdubedit.htm .... have fun..thats a guide to do it in v-dub...holla
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
oops...i meant to say Virtualdub in my first post. the problem is, i would like the final file to be around 700mb? thats why i wanted to know about the encoding part
do they add up to 700MB? or are they bigger? if they are bigger, then you are going to loose quality.
dont worry bout the file size that comes out, when you encode it, using tmpgenc, it will give you the right file size, then if your burner supports overburning, then you can create the vd...holla
both AVI's joined are 1.36GB. i dont want to make a VCD or SVCD i still want to keep it an AVI. i just want to burn the single movie to one CD. what encodeing settings should i use to do this. the final needs to be around 700MB. i other (main) thing i would like to know is what will this look like after i encode it to make it a 700MB file. good/bad. if bad, how bad do u think it might look. if the final one is going to look bad its not really worth it. the orginal is a DVDRip. high HQ
it will look ok. not as good as the original, but good. better than vcd.
use this calculator:
https://www.videohelp.com/calc.htmHis name was MackemX
divx at lower bitrates will look better than mpeg at the same bitrate. try doing a little sample. then see if the quality is good enough. beauty lies in the eye of the beholder.
I really don't understand why you want to join em to fit on one CD in the first place! The movies have originally been made in that format deliberately to achieve a high quality.....you'll be losing a large amount of quality by compressing the movies to fit on one CD...it'll still look good, but the 2 CD versions look superb.
Basically, you'll be doing all the joining and waiting around, then losing quality, all for the sake of saving around 15p (25c) per movie. Gotta be worth that amount to keep the film in its original quality format.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
How to playback file of XviD/DivX (AVI) into QuickTime player (Windows OS)?
By Leo99 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Aug 2008, 23:40 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09 -
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 22:04
