Here's my dilemma. I used Pinnacle Studio 8 to make my VCD because I love the motion menus in the program, however, the program doesn't allow access to the VCD structure to add extra folders.
I want to add a folder of MP3s and photos to the directory. How can I pull the disc apart with the original encoding from the Pinnacle progam intact but stick a few more folders into the same session and return it to disc?
Thx. in advance.
Tygrus
Can anyone help me??? The is one of the last critical things I need to know about VCD.
tygrus -
If you have a finished VCD or a bin/cue set you could use vcdxrip (part of vcdimager) to extract it to source files plus an XML file you can edit. I know VCDEasy has a front-end for vcdxrip, I think most of the other vcdimager front-ends do as well.
VLC player: can someone recompile w/ mplayers h264 codec ?
By vhelp in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2009, 21:40 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
how to recompile customs menu to authored dvd?
By nick101181 in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2007, 18:11 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
