Iv'e tried using the latest TMPEG version inorder to seperate the audio and the video streams from an mpg file but kept getting bad results. I used TMPEG project wizard, and in the aspect ratio I tried any type of PAL/NTSC combination but gotten bad result every time.
when i multiplex the movie in videopack (using the multiplexer which is extremly buggy) and then tried watching the .svd file that I got, the picture didn't look smooth. Tried burning it and got the same problem in my DVD.
anyone has a clue what's the problem?
Have you tried not using the project wizard in Tmpegenc ? Cancel out the wizard the click File\Mpeg Tools. Then pick Simple DeMultiplex, load the stream, and hit the button, and sit back and relax.
SeanWe all like Sheep have gone astray... -
Umm, it does the same thing? Because there are different options in the wizard. And I can't do a source range so testing it will take me a long time. Any other solution? (I will try not using the wizard when I have time)
use dvd2avi, that usaully works awesome for me, and when you recompress, use the divx 5 codec..holla back
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"?
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 15:51 -
Splitting AC3 48Hz 2 Channel into 2 seperate files
By Caliburner9 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2011, 23:51 -
Splitting AC3 Into Seperate Files
By travelagent73 in forum AudioReplies: 4Last Post: 19th Aug 2009, 14:46 -
Video/audio file splitting weirdness
By DoctorDidj in forum ffmpegX general discussionReplies: 2Last Post: 13th Jun 2008, 08:28 -
how can i seperate audio and video from a video file?
By sumeshkri in forum AudioReplies: 4Last Post: 26th Feb 2008, 12:45
