Results 1 to 12 of 12
    Mar 2003
    Whats the easiest way to burn a DivX to DVD? (im using Nero 5.5.10.28)
  2. Member Conquest10's Avatar
    Chicago, IL
    His name was MackemX
    Mar 2003
    Ok im using TMPGEnc but the file gets to big, almost 8000MB... and when i choose the low res option the file gets 4800MB! what am i doing wrong, the movie is just 2 hours long,
  4. Member Conquest10's Avatar
    Chicago, IL
    800 MB will fit on a dvd with more than 3 gigs to spare.
  5. Member Conquest10's Avatar
    Chicago, IL
    the bitrate is what's wrong.
    Mar 2003
    I really appreciate your help, but retard as i am i cant find the options for the bitrate....
  7. Member Conquest10's Avatar
    Chicago, IL
    are you using the wizard?
  8. Member Conquest10's Avatar
    Chicago, IL
    on the guide i provided, its the second picture from the bottom.
  9. Originally Posted by Conquest10
    You're right, but what Rillern said was different: "...but the file gets to big, almost 8000MB...". The only way you'll be able to fit that onto a DVD is if you get it pressed using a DVD-9 disc.
    jawgee
  10. Member Conquest10's Avatar
    Chicago, IL
    ooh, i didn't even see that! i thought it was 2 0s. then you got that bitrate waaayyy too high if its 8 gigs.
    Mar 2003
    Ok i think i know how to do! Thank you for your help
    Jan 2003
    Nassau, Bahamas
    ill recomend ulead dvd movie factory to u.... https://www.videohelp.com/forum/userguides/139093.php . then try that guide..holla
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
