  1. I'm in the middle of converting several of my old VCDs (home movies) to DVDR (take up less space & play on more standalones). I already have a several entry points on the VCD that I want to convert to DVD chapters.
    However, I'm not sure how. I've looked at the "VCD\ENTRIES.VCD" file but it's encoded/not text.
    Is there a VCD Chapter extracter, or some way to manual figure out the entries. Thanks in advance
  2. VCDEasy can extract the XML from a VCD/SVCD which contains the entry points I'm not sure if it was in minutes or frames though I just remember seeing it.
  3. Hmm? Under tools I see VCDxRIP which can convert disc image of (S)VCD to XML (and other files). But I've already got the VCD (the image file is long gone). Maybe I can make a new image and then try running VCDxRIP on it.
