Can anybody help with a small, but very annoying problem I have while trying to use Cinemacraft MPEG Encoder to convert a few AVI films I have to MPG, so I can shove them onto DVD
I know I could use another converter or TMPGenc, which I will end up doing I think, but solving this "problem" will stop it bugging me as well
When trying to convert certains AVI's, I get the same error message about the audio codec, I don't think its down to it not being available, but from reading a bit about this error on the MS developer site, it may be a problem with the actual encoder
I get this error :
acmstreamopen() failed: Error 512
The wave format is 85
Any suggestions as to what is causing this, and how to solve it, so CCE can convert the problem AVI's.
Not a problem to TPMGenc, but CCE, and also Mainconcept Encoder as well
I know I can extract the audio stream, using VirtualDub, and convert it using Mainconcept adding the stream back to the final output, longwinded one one program should be able to do it all
Thanks in advance
as far as the audio, what do you use to extract wav files, v-dub...aiight...dont use that, try gold wave its a bit better, then tell me how it goes..holla
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Okay, I'll give GoldWave a try, I used to use that ages ago, but the latest version is now upto v5.0 beta, so I'll see whats improved, but
It still doesn't answer my question as to what is causing the error
Also, as far as I can tell, might be mistaken, it won't be the first or last time ......... CCE cannot import an audio stream, it just take the main stream and if it has audio uses that, there isn't a way to add your own audio stream to the output stream
Strange message at installation
By sd1936 in forum ffmpegX general discussionReplies: 1Last Post: 28th Sep 2008, 08:46 -
Strange Error Message when trying to encode to DIVX
By Meiso in forum ffmpegX general discussionReplies: 1Last Post: 1st May 2008, 10:20 -
unsupported audio type error message in AutoGK
By ham2405 in forum AudioReplies: 2Last Post: 26th Dec 2007, 17:53 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23 -
Strange message from dvdshrink
By Hendra in forum DVD RippingReplies: 3Last Post: 14th Sep 2007, 12:38
