just purchased LITEON 48X24X48 writer but can only burn @12 speed. Computer spec = cpu athlon2000,512ram, 40 gig hard drive, dvd cd-romany help would be appreciated.
make sure the media u r using is the right speed, then check the burning speed from the program u r using to burn ie: nero, roxio or the 1 built in in windows xp, all of them are fully configurable for the burning speed, then is up to the disk
TheMoviezMan
Writer not burning at 16x like it should
By championjosh in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Mar 2008, 03:59 -
Writer burning discs erratically
By uNderdog_101 in forum DVD & Blu-ray WritersReplies: 11Last Post: 28th Nov 2007, 15:08 -
new dvd writer problems
By carstd01 in forum DVD & Blu-ray WritersReplies: 6Last Post: 25th Nov 2007, 13:58 -
Problem with burning using my LG writer won't go away
By pwil30 in forum DVD & Blu-ray WritersReplies: 7Last Post: 16th Jul 2007, 11:12 -
dvd writer problems
By ellabbs in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 17:05
