Why is it when I used this program, it wants to keep all files it has touched in use even when they arent loaded up?
I take some digicam avi movies, convert them to divx then want to delete or move the original, low and behold, the PC thinks it is still open or being used by another person. I now have dozens of files this way. How do I release them?
Tygrus
Using windows XP by any chance?
https://www.videohelp.com/forum/viewtopic.php?t=100406&highlight=delete -
Thanks much. The reg edit worked and now I can delete my files.
However, I am still having trouble capturing from the PC screen. When I go to save the file, it gives a similar error as in files being used by another person or program. Is this related at all?
Tygrus -
How are you doing this? using the print screen key or some capture app?Originally Posted by tygrus2000
I am using a vid. screen capture program like Hypercam. It wont save after the capture, says video file is already in use.
tygrus -
Sorry can't help with that one, try posting the question in the off topic forum
VDub wont load *.VCF files in command line mode.
By zzyzx2 in forum Video ConversionReplies: 11Last Post: 15th Sep 2011, 06:48 -
how 2 open mp4 & mkv video files in vdub
By naveenkrish in forum EditingReplies: 2Last Post: 19th Jun 2010, 22:14 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 02:23 -
Joining 33 avi files with vdub
By aruwin in forum EditingReplies: 3Last Post: 9th Oct 2008, 03:30 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 02:43
