Why are the SVCD resolution defualts 480x480? My video gets distorted. Can I make a MPEG2 SVCD at 720x480? I have Ulead VS7 and MF2.
Yes you can make SVCD's at 720x480 resolution. When I was making SVCD's I always used 720x480. The purists will tell you that it's acually an XSVCD since it's no longer "standard". As with any new encode you should make a test to be certian your DVD player can play it correctly.
My DVD player doesn't play SVCD, only VCD. I was going to try the VCD header trick using SVCD at 720x480.
If your DVD player supports XVCD why not make a 720x480,2500kbps VCD?But I would use TMPGEnc to convert and Nero to author and burn because Ulead products can't burn XVCD's with menus.
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
