can i encode a VCD which has parameters that are above the "standard" format ie: higher res than 352 X 240 (NTSC), higher video/audio bitrate and have them still work on a DVD player (which is not in the computer)...i know that SVCD has a res of 480 X 480 and overall better standard setting.
thanks for your help![]()
no you cant, thats the specifications for a vcd, other wise it wont be able to be played, holla
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Yes I do it all the time but my dvd player plays anything Acoustic solutions, If your dvd plays svcd's then you should be okay with useing higher settings, i was never that happy with the quaility of vcd which is why i tryed experimenting with all the different settings, if its strictly vcd the no chance, never tryed the header trick, i saved up and bought a dvd burner, all these years wasted encoding video.
You're talking about making an XVCD. Increasing the bitrate might be OK, but changing the resolution isn't very likely to work. Have you tried the Header Trick?It allows some VCD-only players to play SVCD's. There's a guide in the Convert Section. 8)
1080p Standards?
By thezanny in forum Video ConversionReplies: 4Last Post: 17th Aug 2011, 10:37 -
AVIAddXSubs Question: PS3 can't read Japanese Subs
By NikoNikoNeko in forum SubtitleReplies: 3Last Post: 20th Oct 2010, 21:21 -
Can VBscript/Batch read MPEG file?
By Cazz in forum ProgrammingReplies: 11Last Post: 3rd Sep 2010, 07:50 -
Complex Anime ripping question. Please read. TYVM! ^_^
By Dratheus in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2009, 01:52 -
New Youtube standards
By johnnywellas in forum Video Streaming DownloadingReplies: 26Last Post: 11th Dec 2008, 20:17
