Hello,
For DVD that contain Full & Wide screen movie.
when the DVD is insert and run, it first goes to a format selection menu(F or W screen),which is in the VTS_09_0.vob.
After your selection it goes to the main menu that is in VTS_01_0.vob, it's the only file where the menu is store whatever your format selection is.
I' ve kept everything except the Full screen movie vobs, that I've replace by a small vob (I' ve edit it's ifo) so I keep the original structure.
I can burn it like that and make the Full screen format option unavailable and then it' ll work perfectly (already done that with another movie :] )
but I would like to skip this selection menu and directly go to the main menu that' ll launch the Widescreen movie.
I would like to know if it' s possible, so it' ll looks better, I won' t see an unavailable option and won' t have to clic on wide screen option to see the menu.
If YES, how ?????
I think it's possible by using IFO Edit, but don' t know what to edit :/
Thanks a lot 4 ur help
I have tryed to di this with Darkness Falls.. IFOedit didn't help and removing the vobs didn't work (standalone DVD crashing)
I finnaly made a movie only copie since I got no real awsner to my question posted few day ago..
I wish you better luck
Can IFO-Edit merge files?
By Djard in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2011, 11:50 -
trying to edit dvd get VTS_18_0.IFO contains bogus data error, FIX?
By Denvers Dawgs in forum Authoring (DVD)Replies: 6Last Post: 2nd Apr 2011, 17:45 -
Extreme frustration: PAL to NTSC, using IFO Edit
By gabelogan99 in forum Authoring (DVD)Replies: 4Last Post: 22nd Jan 2011, 15:02 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 11:39 -
using ifo edit
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:19
