i have a 3gb mpg and want to make a dvd of it
any idea how?
cheers
if it is within the dvd standard( www.dvdrhelp.com/dvd#tech and check the mpg settings with avicodec www.dvdrhelp.com/play#identify ) you can author it directly to dvd
www.dvdrhelp.com/author#dvd
or else you have to convert it to dvd standard, www.dvdrhelp.com/convert#dvd -
I suggest that you use a professional tool which you can find in:
http://www.pcworld.com/downloads/file_description/0,fid,22527,00.asp
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 16:51
