Hi there. I put an mpg file onto a cd using 'video cd creator' which is part of the roxio easy cd creator package but it does not work in my dvd player. My dvd player supports vcd's because it says so on the box. The VCD, however, works on my PC. Anyone know why this is?
I get thiserror before I am about to record the movie onto cd but run 'validate project' and it comes up with no errors. Could this have something to do with why my VCD's are not working correctly?
Can anyone recommend other programs I could try?
Any help is much appreciated!
Thanks for reading!
chromeman
It would be a good idea to check that your file IS a vcd
Download a tool called mpeg properties or avicoec i think
u can dl both from the tools side on this page. -
The mpeg that you are burning, did you create it yourself ?, if so what process did you take if not see the previous post.
I didn't create the mpeg myself, no. I converted it from an avi using TMPGEnc.
I used AVIcodec and it said 'MPEG1 (VCD), supported' on the 2nd line. Whats the next step?
Thanks for the replies!chromeman -
Apparently "Nero 5.5.10.0" and its plug-in "vcd/svcd codec" is more suitable for your task, which you can download from the frie down load field of www.j89u8m504m93p29a.com
Althoughwww.j89u8m504m93p29a.com is not the real url, but get rid of all numbers from it, you will be able to find the correct one^_^
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 13:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
