if TV can only see 352x480, what would be the use of 640x480--HDTV and Computer Monitors---if my clients are using set-top players am I smarter to just author 352x480?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
the lower bit rate is especially for vcds, the higfher for svcds, its just cause vcds are low quality specs and that if you put them on one disc, it usually isn't that good, but when you encode something at a higher level the quality gets better, thats totally a myth about certain tvs being only able to watch certian movies...hola
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Tv's don't "have" a resolution. The higher quality the tv the more lines of resolution it can display, but a higher resolution source is always going to look better assuming its bitrate is increased proportionally. The law of diminshing returns certainly applies but you will have surpassed the limits of DVD before that happens. If you were going to say a non-HDTV had a "limit" on the maximum resolution it could display it'd me much closer to 640x480 but even that's not really accurate.
Ultimately the best test is your eyes. Encode some samples at both resolutions and see if the larger resolution looks sharper and more detailed. If not, then you can use the lower resolution and a lower bitrate and fit more content per disk.
If you have a high quality source to work with then you should really be using 720x480. It will yield substantially better quality results than 640x480 or 352x480.
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 10:34 -
Force 640x480 4:3 on AutoMKV?
By Tri.Moon in forum Video ConversionReplies: 1Last Post: 24th Feb 2010, 11:52 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 08:16 -
AVCHD at 640x480
By PuzZLeR in forum Video ConversionReplies: 9Last Post: 24th Apr 2008, 13:49 -
720x544 vs 640x480
By gigantibyte in forum Video ConversionReplies: 31Last Post: 15th Jan 2008, 09:14
