have an pioneer a05 with firmware 1.30. i been using optodisc and ritek and burning them with nero.once in a while i burn a disc 100% but when i but it in my dvd player it saids erorr so i check it out with dvd decrypter to see the vob file and its telling me that the dvd is empty but i can clearly see that thats not true the dvd is burnt . could it be the firmware?? or the dvd burner it self i know its not the media cause this even happens with the pioneer dvd_rw that came with the pioneer please help
thanks
I had that happen once than I realized I had checked the "Test and Burn" option and the system ejected the disk after testing it without burning it. I had to put it back in and had to burn it, no problems at all.
If you're sure it's not that than take the unit back to where you bought it from it might be faulty.
Cheers,
Kuka -
I had the exact same problem. My solution? Stop using NERO and start using RecordNOW DX. My copy shipped with the A05.
i also tryed recordnow dx(sony) and max 4.6 and it give me even more burning problem than nero or do i have to get recordnow dx from pioneer?? or the one that came with my old sony burner is the same one?
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 08:03 -
Pioneer DVR 533HS Problem
By Hollywood_Mike in forum DVD & Blu-ray RecordersReplies: 25Last Post: 13th Aug 2008, 11:35 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 04:36 -
Problem, with my PIONEER 111d writer
By Gewin in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Dec 2007, 06:51 -
Pioneer DVR 533 Problem -
By chris_james in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Aug 2007, 01:59
