Hi,
I`m trying to convert a couple of AVI files from the web into (S)VCD and I`m getting the films onto 1 and 2 CD`s but I always get sync probs with the sound. I extract the audio using VDUB and input that in TMPGenc when I convert the AVI, but when I play it back on my dvd player its starts ok then a little while into the film it can be 1 or 2 seconds out then a little later it will be ok again.
Do I have to live with this or is there something I can do?
Thanks Doot.
You don't have to live with it, but fixing it requires diagnosing the problem first. The most common cause of lack of sync is bad frames in the source file, they must always be removed first before converting. Another common cause is the video and audio durations not matching; The audio can be shrunk or stretched to fit using "Time Warp" in Goldwave. Another possible cause is that the sync was out in the source file; The audio can be started earlier or later by using the audio delay function in TMPGEnc.Originally Posted by doot
Do a forum search as this is easily the most asked about topic and there are lots of posts on it. 8)"Art is making something out of nothing and selling it." - Frank Zappa -
I can`t use that as its ok to start then it will get out of sync then can be ok again. I`ll have a look at some old posts for a solution.The audio can be started earlier or later by using the audio delay function in TMPGEnc
Thanks Doot -
Sounds like maybe a playback problem. Does it play OK on your PC? If so, then maybe try burning at a lower speed, try different media, or change the bitrate that you encoded at. If you're using CBR then lower the bitrate a bit. If you're using 2-pass VBR, then set your max. a little lower and your min. a little higher with padding turned on.Originally Posted by doot"Art is making something out of nothing and selling it." - Frank Zappa
No the playback is not ok on the PC, its not as bad as my DVD player but is out of sync. I use PowerDVD 4 for MPG2 and windows player for MPG1
Doot
Audio Sync Problems
By mattr in forum MacReplies: 4Last Post: 7th Jul 2008, 09:55 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 14:14 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
