I am a very frustrated home movie user trying to get DV home movies onto SVCD rather than accepting poorer quality of VCD. I have an encoding problem (I think) to achieve ff/fr & other PBC on my disks. DVD player is Philips 703 with updated firmware. Plays SVCD stream nicely but haven't checked on any time limits for ff/fr yet - other problems are bigger. Apologies for the long item..
Scenario is:
* DV captured & edited with Pinacle DV with a 53 minute video split & saved to 4 avi files (DV Video) to manage file sizes
* the 4 avi files batch encoded to standard SVCD template with TMPGEnc with 2pass VBR (max 2400, Min 400, Av 1620) with sharpening then joined with TMPGEnc
* TSCV 7.2.2 to cue/bin (with 'update scan offsets') then burned cue with CDRwin
Outcomes are varied:
* happy with picture quality
* no ff/fr, chapters generally work
* error message on TSCV log as follows
scanning mpeg sequence item "sequence-1" for scanpoints...
APS' pts seems out of order (actual pts 0.693344, last seen pts 2808.893356) -- ignoring this aps
writing track 1 (ISO9660)...
'update scan offsets' option enabled for the following tracks!
writing track 2, MPEG2, PAL 2/3 D-1..etc etc etc
finished ok, image created with 320948 sectors [71:19.23]
Having achieved a good quality video but no ff/fr I tried demux with TMPGEnc & remux with bbMPEG (selecting update scan offsets with bbMPEG) and then using TSCV to send to cue/bin (again with update scan offsets) Same result but different error message:
scanning mpeg sequence item "sequence-1" for scan points...
mpeg scan: pack header code )0x000001ba) expected, but 0x000001b9 found (buflen = 4)
...PEM (program end marker) found instead of pack header; should be in last 4 bytes of pack
bad packet at packet #322687 (stream offset 74992458-- remaining 4 bytes of stream will be ignored
writing track 1 (ISO 9660)... the rest is then the same
Now being totally annoyed, I tried the original method with only one of the avi files, approx 16 minutes long.
No error on TSCV log, ff & fr working well (4X, 8X & 32X) Everything seems fine (one instance of sync problem when stopping ff). Cannot blame DVD player yet & now assume an encoding/authoring issue. Why does it seem so difficult to get approx 1 hr DV tape onto one CD...
Any suggestions very welcome.
_________________
mdez
<font size=-1>[ This Message was edited by: mdez on 2001-09-17 23:41:37 ]</font>
Results 1 to 1 of 1
Blu-ray Encoding and Authoring Help!!!
By jbandy1 in forum Authoring (Blu-ray)Replies: 7Last Post: 7th Aug 2010, 12:32 -
TMPGEnc Authoring Works 4 Encoding
By mabrandt in forum Authoring (DVD)Replies: 3Last Post: 28th Oct 2009, 11:45 -
DVD authoring without re-encoding
By siluet in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2009, 05:36 -
Encoding & Authoring On Vista Help
By prcole18 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2008, 12:55 -
Regarding MPEG2 Encoding (DVD authoring)
By Wuhtzu in forum Video ConversionReplies: 9Last Post: 10th May 2007, 18:07
