I've long used TMPGEnc, but having tried out CCE for a few days I'm blown away by its speed and quality and I really want to carry on using it.
However I'm having problems with importing the DVD MPG into Ulead MF2, its trying to re-encode, which we all know is a waste of time.
Here my procedure -
1) Check AVI for bad frames first using Virtuadub
2) Frameserve from virtuadub, applied a resize filter to ensure video size is 740x480
3) Import the vdr into CCE. set audio to stereo, 48KHz @ 256kbps
4) Set video options to M=3 N/M = 5 (CCE manual says these are the defaults)
5) Tick the "Make DVD Compliant box
6) Add Seq end code is ticked
7) Sequence header set to 1
8) Packet size set to 2048
9) Set Video mode to MPEG2 ES multipass VBR
10) Set bit rates Avg 6000, Min 2000 Max 7000
11) start to encode and when I import the MPV and MPA files into Ulead Movie Factory 2, the damn thing wants to re-encode. I've ticked the do not rencode DVD complient box. I've tried the customise template to make sure the Ulead settings match the CCE settings.
I am now at my wits end and any help would be really appricated.
Ironballs
Your CCE encoding should have a bitrate that is slightly below that of the project setting in DVD MovieFactory to avoid re-encoding.
Have you tried that, yet?
Jerry Jones
http://www.jonesgroup.net
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 13:03 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
