Hi,
I got 5 Datawrite DVD+R 2.4x the other day.
I burnt a movie to the disc to test it out. It plays fine in my computer, but not in a playstation 2 or my set top player, nor my friends.
What the hell is wrong????/
John
I USE DATAWRITE +R ALL THE TIME AND THEY PLAY PERFECT ON STAND ALONE PLAYERS AND PS2 MUST BE THE WAY YOUR RECORDING THEM. TRY NERO 5.5.10.28 USING DVD VIDEO CHECK ISO LEVEL 1 AND BELOW ISO 9660 UNCHECK EVERY THING ELSE. SELECT ALL YOUR FILES AND CUT AND PEST YOUR FILES TO THE RED VIDEO - TS FOLDER. BEFORE BURNING TICK BOOK TYPE DVD-ROM AND BURN
8)
I got some Datawrite DVD+R discs a while back and they were the worst I ever tried. NONE of the 20 discs I tried worked. They burned fine but when viewed on any stand-alone player they started to break up near the end of the disc. tha ones I had where manufactured by Pro disc.
DVDinfo:
08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 00 50 52 4F 44 49 53 43 00 52 .......PRODISC.R
30 31 00 38 23 54 37 0A 02 5A 70 02 C8 67 19 19 01.8#T7..ZP..G..
STAY AWAY FROM THESE DICS! -
Do you have a Sony DRU-500A by any chance? I had some Bulkpaq and Nashua DVD+R discs made by Prodisc, and I couldn't burn one successfully! They ALL failed at 83%
during the burn, no matter which firmware I used
I do have the Sony DRU-500AX, but I haven't tried to burn these discs with it yet. The non-working discs I made where all burned with my old burner, a Ricoh MP5125A so I can tell you it is not the burner it is the shitty manufactures fault...
NEVER BUY ANY PRODISC MADE MEDIA -
I've just bought some Nashua branded DVD-R (it says made of MAKROLON on the front). Appears to burn okay (2x) but DVD playback starts to break up at random points on playback (PC and standalone DVD player).
I won't touch these again - and yes, I've got a Sony DRU-500
DVDinfo :-
00 6A 00 00 01 40 C1 FD 9E D8 50 00 02 7A 0C 15 .j...@....P..z..
77 78 90 00 03 45 75 72 6F 44 69 00 04 67 2D 44 wx...EuroDi..g-D
69 73 63 00 05 CC C0 00 00 00 01 00 00 00 00 00 isc.............
Sonik Data DVD+R DL ---- CRAP!!!!!!!
By Regor21 in forum MediaReplies: 2Last Post: 20th Aug 2010, 08:04 -
Looks great on computer but crap through DVD
By pftjim in forum Authoring (DVD)Replies: 28Last Post: 20th Feb 2010, 21:00 -
Datawrite disc wont read on pc and laptop
By lb77 in forum DVD RippingReplies: 3Last Post: 11th Nov 2009, 09:20 -
Why do DVD's look like crap on HD tv's and computer monitors?
By brassplyer in forum Authoring (DVD)Replies: 62Last Post: 29th Aug 2009, 11:36 -
Which DVD-R?? Datawrite??
By nos707 in forum MediaReplies: 7Last Post: 18th Sep 2008, 19:41
