  1. Hi all. I'm getting a bit confused here about video formats and I need some help. First off, I have looked at the glossary and other bits of info on the left side of the screen, but did not find what I was looking for there. I don't want to do any more coasters, so please advise me on just where I'm going wrong. I have 2 video files, one with the properties of "MPG" and the other with the properties listed as "MPEG". Last weekend I burned a DVD with the file that's identified as "MPG" and I got both picture and sound. Great! This weekend I tried to do a DVD with files that are identified as "MPEG" and I got video, but no sound. What exactly is the difference between the two types of files? I thought they were pretty much one in the same? If not, what program would be a good suggestion to use to help me with this problem? Currently I am using Nero Vision Express version 1.0.4.2. to burn my DVDs and I have a Verbatim DVD+RW/+R drive (computer actually recognizes at as an NEC DVD+RW ND-1000A). Any help is appreciated!
    Dec 2002
    Texas USA
    In the old days PC only allowed 3-char extension. Still same file type.
    So:
    MPG=MPEG
    JPG=JPEG
    TIF=TIFF
    etc, etc, etc
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Not all mpegs are created equal. Mpegproperties is a program found in the Tools section. It will analyze mpg files and tell you the basic properties. If you're making a DVD then you need to make sure that your mpeg's are DVD compliant.
