I've saved a movie from Quicktime Pro to mp4 format and then opened it in VirtualDub. It opens but the picture is distorted. VirtualDub's File Information claims it's Divx Pro 5.0.2 format, which I guess is the problem.
Any thoughts on how to fix this?
I'm using VDub 1.4.13, Quicktime 6.1
If you still have the Quicktime source file and have Quicktime Pro 6, then use that to convert it to AVI and then open it in virtualdub, and from there you can work with it.
The problem with that is that I don't have a very wide range of codecs available when I export to AVI. Quicktime seems to have a fixed list of codecs. I'd love to be able to export to Divx or Hufyuv but I don't have that option.
If there's a way of enabling the codecs installed on my PC within Quicktime then that would be just as good. -
I too would love to be able to swap codecs from Quicktime to Video for Windows and vice versa, but I do not think that is possible. But if someone out there knows a way, please share.
My suggestion was actually that you use Quicktime to convert to uncompressed AVI (which I've done), then do whatever editing you want in Virtualdub, and then use Virtualdub to compress to your favorite compressed AVI codec. Of course, you'll need to make sure you have enough disc space for that uncompressed AVI file which will be huge.
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 08:06 -
Rendered MP4 Files - Video but no audio in Quicktime on different PC
By pauldsc in forum Software PlayingReplies: 1Last Post: 5th Nov 2011, 09:24 -
Problem with MP4 files and VirtualDub on W7
By asterixvader in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2010, 16:09 -
a problem opening MKV or MP4 files
By gis4ever in forum Video ConversionReplies: 10Last Post: 7th Jul 2010, 12:39 -
Need help in importing MP4 files in VirtualDub...
By hash13 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2010, 07:29
