I have a VHS I'd like to capture and record to DVD but it sounds like it was recorded in a wind tunnel.
What are the simplest, newb-friendliest options available?
I am using an ATI AIW 8500DV.
eX
I have the same problem off and on with my Nvidia Capture Card using VirtualDub. I'm thinking it may have something to do with overdriving the Audio Record "Line In" on my sound card, and I'm still experimenting with different settings. Mine is set about 3/4 way to the top now, and the volumn "seems" normal on playback. When I check the level with Wavelab Lite it actually registers a little low, but the final product is distorted if I run the volumn up very high on DVD playback, so something is amiss! Be patient ....I'm sure someone will jump in has had the same problem and found the solution.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776 -
Good captures? Cleaning the audio? Easy? ATI?
YOU'RE IN LUCK MY FRIEND!
Goto the VHS->DVD guide here:
http://lordsmurf.hypermart.net/conversion/dvdguide.htmI'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
I'll check out the link. But maybe I was not clear. The VHS sounds like crap.
I want to put it onto DVD but I'll need to clean up the noise on my PC...
** I see you have answered my question with your link. thank you.eX
Tools Needed Clean up iPhone Concert Video's Audio
By xr280xr in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2011, 18:55 -
Do capture cards clean the signal ?
By davexnet in forum Capturing and VCRReplies: 18Last Post: 29th May 2010, 21:45 -
.flv demux for audio clean up
By longislandgrafix in forum EditingReplies: 1Last Post: 29th Jan 2009, 11:17 -
Clean up audio on AVI file
By marybutts in forum AudioReplies: 2Last Post: 11th Jan 2008, 07:15 -
Capture DVD to be edited/clean?
By mlong30 in forum Capturing and VCRReplies: 13Last Post: 17th Jun 2007, 23:13
