    Aug 2002
    England
    Hi
    This is what I am trying to achieve....
    You know when you encode divx/xvid to VCD it makes the video full screen thus making everyone taller and thinner than they should be.
    What I am after is simple instructions on how to add a black border to the top and bottom of the video to give it that widescreen look. So that everything looks more in proportion.
    I don't want too thick borders tho.
    Can this be done?
    Cheers
    Fozzee
    In tmpgenc it is just to choose full screen (keep aspect ratio) under settings->advanced->video arrange method and 1:1(vga) under source aspect ratio.
    With most other encoders you must add the borders with a external tool like virtualdub or avisynth and frameserve to the encoder.
    Aug 2002
    England
    Cheers
    Fozzee
    Aug 2002
    England
    I find a few of them end up too narrow.
    Is there anyway to change this??
    I know its the proper aspect ratio but it often looks better a little more stretched. Any ideas?
    Cheers
    Fozzee
  5. Member Conquest10's Avatar
    Chicago, IL
    you can do a custom resize. making it whatever size you want.
    His name was MackemX
    Aug 2002
    England
    Please explain in more detail...
    Which settings?? How do you judge it??
    Cheers
    Fozzee
  7. Member Conquest10's Avatar
    Chicago, IL
    in the advanced tab, set the video arrange method to center (custom size). you can then go into clip frame, arrange setting and look at how the video will come out.
    Aug 2002
    England
    Got it cheers
    Fozzee
